security dynamic-authorization group show
Display Dynamic Authorization groups
The security dynamic-authorization group show command displays information about the dynamic authorization groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects dynamic-authorization groups for this Vserver.
[-name <text>]- Group Name-
Selects dynamic-authorization groups that match this group name.
[-excluded-usernames <text>,…]- List of Excluded Users-
Selects the dynamic-authorization groups that match the specified excluded username.
[-comment <text>]- Comment-
Selects the dynamic-authorization groups that match this comment.
The example below displays dynamic authorization group information for the Vserver vs1 .
cluster1::> security dynamic-authorization group show -vserver vs1
Vserver: vs1
Group Name: NETAPP_ENG
List of Excluded Users: user1, user2, user12
Comment: -
