system services manager install show
Display a list of installed services
The system services manager install show command displays information about installed services.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-service <text>]- Service
Selects information about installed services that have the name you specify.
- [-version <service version>]- Version
Selects information about installed services that have the version number you specify.
- [-constituent <text>]- Constituent
Selects information about installed services that have the constituent process you specify.
- [-nodes {<nodename>|local}]- Nodes
Selects information about services that are installed on the nodes you specify.
- [-description <text>]- Description
Selects information about installed services that match the description you specify.
The following example shows typical output from a two-node cluster.
cluster1::> system services manager install show
Service           Version Constituent Nodes
diagnosis
                  1.0     schmd       node1, node2
                  1.0     shmd        node1, node2
2 entries were displayed.
 PDFs
PDFs
