system services manager install show
Display a list of installed services
The system services manager install show command displays information about installed services.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-service <text>]- Service-
Selects information about installed services that have the name you specify.
[-version <service version>]- Version-
Selects information about installed services that have the version number you specify.
[-constituent <text>]- Constituent-
Selects information about installed services that have the constituent process you specify.
[-nodes {<nodename>|local}]- Nodes-
Selects information about services that are installed on the nodes you specify.
[-description <text>]- Description-
Selects information about installed services that match the description you specify.
The following example shows typical output from a two-node cluster.
cluster1::> system services manager install show
Service Version Constituent Nodes
diagnosis
1.0 schmd node1, node2
1.0 shmd node1, node2
2 entries were displayed.
