security login totp show
Display TOTP secret
The security login totp show command displays information about secret keys.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
Selects the secret keys that match this parameter value.
[-username <text>]- Username-
[-fingerprint <text>]- TOTP Secret key fingerprint-
Select the secret keys that match this parameter value.
[-enabled {true|false}]- TOTP Status-
[-comment <text>]- Comment-
The example below displays secret key information for the user named tsmith.
cluster1::> security login totp show -username tsmith UserName: tsmith TOTP SHA Fingerprint: 7038eb494f8b86726bdfae9da1fbadb348f8fe26116f49e09f718a7b8bdd73b8 TOTP status: true Comment: This is a new key
