security login totp show
Display TOTP secret
The security login totp show command displays information about secret keys.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the secret keys that match this parameter value.
[-username <text>] - Username
[-fingerprint <text>] - TOTP Secret key fingerprint
Select the secret keys that match this parameter value.
[-enabled {true|false}] - TOTP Status
[-comment <text>] - Comment
The example below displays secret key information for the user named tsmith.
cluster1::> security login totp show -username tsmith
UserName: tsmith
TOTP SHA Fingerprint:
7038eb494f8b86726bdfae9da1fbadb348f8fe26116f49e09f718a7b8bdd73b8
TOTP status: true
Comment: This is a new key
