ONTAP commands
system license clean-up
Remove unnecessary licenses
This command manages licenses in the cluster that have no effect, and so can be removed. Licenses that have expired or are not affiliated with any controller in the cluster are deleted by this command. Licenses that cannot be deleted are displayed with reasons for the non-deletion.
[-unused <true>] - Remove unused licenses
If you use this parameter, the command removes licenses in the cluster that are not affiliated with any controller in the cluster.
[-expired <true>] - Remove expired licenses
If you use this parameter, the command removes licenses in the cluster that have expired.
[-n, -simulate <true>] - Simulate Only
If you use this parameter, the command will not remove the licenses. Instead it will display the licenses that will be removed if this parameter was not provided.
The following example simulates and displays the licenses that can be cleaned up:
cluster-1::> system license clean-up -expired -unused
The following licenses were safely deleted:
Serial number: 1-80-000011
Owner: cdancluster-1
Package                   Reason
CIFS                      License has expired
Serial number: 4067154888
Owner: none
Package                   Reason
Cloud                     License has expired
Serial number: 1-81-0000000000000004067154999
Owner: none
Package                   Reason
iSCSI                     License unused by any node in the cluster
The following licenses are either expired or unused but cannot be safely deleted:
Serial number: 4067154778
Owner: node1
Package                   Reason
Cloud                     Feature would be impaired upon removal
Serial number: 4067154779
Owner: node2
Package                   Reason
Cloud                     System generated license
