system license clean-up
Remove unnecessary licenses
This command manages licenses in the cluster that have no effect, and so can be removed. Licenses that have expired or are not affiliated with any controller in the cluster are deleted by this command. Licenses that cannot be deleted are displayed with reasons for the non-deletion.
[-unused <true>]
- Remove unused licenses-
If you use this parameter, the command removes licenses in the cluster that are not affiliated with any controller in the cluster.
[-expired <true>]
- Remove expired licenses-
If you use this parameter, the command removes licenses in the cluster that have expired.
[-n, -simulate <true>]
- Simulate Only-
If you use this parameter, the command will not remove the licenses. Instead it will display the licenses that will be removed if this parameter was not provided.
The following example simulates and displays the licenses that can be cleaned up:
cluster-1::> system license clean-up -expired -unused The following licenses were safely deleted: Serial number: 1-80-000011 Owner: cdancluster-1 Package Reason ------------------------- ----------------------------------------------------- CIFS License has expired Serial number: 4067154888 Owner: none Package Reason ------------------------- ----------------------------------------------------- Cloud License has expired Serial number: 1-81-0000000000000004067154999 Owner: none Package Reason ------------------------- ----------------------------------------------------- iSCSI License unused by any node in the cluster The following licenses are either expired or unused but cannot be safely deleted: Serial number: 4067154778 Owner: node1 Package Reason ------------------------- ----------------------------------------------------- Cloud Feature would be impaired upon removal Serial number: 4067154779 Owner: node2 Package Reason ------------------------- ----------------------------------------------------- Cloud System generated license
