security anti-ransomware volume space show
Display the details of anti-ransomware space usage
This security anti-ransomware volume space show displays the space usage by Anti-ransomware feature.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name
This parameter specifies the Vserver on which the volume is located.
- [-volume <volume name>]- Volume Name
This parameter specifies the name of the volume whose space usage details are to be shown.
- [-space-used-by-snapshot {<integer>[KB|MB|GB|TB|PB]}]- Space Used by snapshots
This parameter shows space usage by Anti-ransomware Snapshot copies.
- [-space-used-by-logs {<integer>[KB|MB|GB|TB|PB]}]- Space Used by logs
This parameter shows the space used by the Anti-ransomware logs.
- [-total-space-used {<integer>[KB|MB|GB|TB|PB]}]- Total space used by anti-ransomware
This parameter shows the total space used by the Anti-ransomware feature.
- [-no-of-snapshot <integer>]- Number of Anti-ransomware Snapshot Copies
This parameter shows the total count of the Anti-ransomware Snapshot copies.
The folowing example shows a sample output for this command:
clus1::>> security anti-ransomware volume space show
                       Space Used By Space Used By Total Space Snapshot
Vserver    Volume      Snapshot      logs          Used        Copies
vs1        vol1             308KB            8B       308.0KB                2
 PDFs
PDFs
