security anti-ransomware volume space show
Display the details of anti-ransomware space usage
This security anti-ransomware volume space show displays the space usage by Anti-ransomware feature.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>] - Volume Name
This parameter specifies the name of the volume whose space usage details are to be shown.
[-space-used-by-snapshot {<integer>[KB|MB|GB|TB|PB]}] - Space Used by snapshots
This parameter shows space usage by Anti-ransomware Snapshot copies.
[-space-used-by-logs {<integer>[KB|MB|GB|TB|PB]}] - Space Used by logs
This parameter shows the space used by the Anti-ransomware logs.
[-total-space-used {<integer>[KB|MB|GB|TB|PB]}] - Total space used by anti-ransomware
This parameter shows the total space used by the Anti-ransomware feature.
[-no-of-snapshot <integer>] - Number of Anti-ransomware Snapshot Copies
This parameter shows the total count of the Anti-ransomware Snapshot copies.
The folowing example shows a sample output for this command:
clus1::>> security anti-ransomware volume space show
                       Space Used By Space Used By Total Space Snapshot
Vserver    Volume      Snapshot      logs          Used        Copies
vs1        vol1             308KB            8B       308.0KB                2
