security anti-ransomware volume space show
Display the details of anti-ransomware space usage
This security anti-ransomware volume space show displays the space usage by Anti-ransomware feature.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>]- Volume Name-
This parameter specifies the name of the volume whose space usage details are to be shown.
[-space-used-by-snapshot {<integer>[KB|MB|GB|TB|PB]}]- Space Used by snapshots-
This parameter shows space usage by Anti-ransomware snapshots.
[-space-used-by-logs {<integer>[KB|MB|GB|TB|PB]}]- Space Used by logs-
This parameter shows the space used by the Anti-ransomware logs.
[-total-space-used {<integer>[KB|MB|GB|TB|PB]}]- Total space used by anti-ransomware-
This parameter shows the total space used by the Anti-ransomware feature.
[-no-of-snapshot <integer>]- Number of Anti-ransomware Snapshot Copies-
This parameter shows the total count of the Anti-ransomware snapshots.
The following example shows a sample output for this command:
clus1::>> security anti-ransomware volume space show
Space Used By Space Used By Total Space Snapshot
Vserver Volume Snapshot logs Used Copies
vs1 vol1 308KB 8B 308.0KB 2
