volume quota off
PDF of this doc site
Creating your file...
Turn off quotas for volumes
This command creates a job to deactivate quotas for the specified volume. You can monitor the progress of the job by using the job show and job watch-progress commands.
-vserver <vserver name>
- Vserver Name-
This specifies the name of the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the name of the volume on which you are deactivating quotas.
[-foreground <true>]
- Foreground Process-
This optionally specifies whether the job created for deactivating quotas runs as a foreground process. The default setting is
false
(that is, the operation runs in the background). When set totrue
, the command will not return until the job completes.
The following example deactivates quotas on the volume named vol1
, which exists on Vserver vs0
cluster1::> volume quota off -vserver vs0 -volume vol1 [Job 23] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
The following example uses a 7G-compatible command to deactivate quotas on the volume named vol1
cluster1::> vserver context vs0 vs0::> quota off vol1 [Job 25] Job is queued: Quota OFF Operation on vserver vs0 volume vol1.
