template show-permissions
Display Template Allowed and Disallowed System Objects
The template show-permission command shows all the system objects that are allowed and disallowed for the current user.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-name <text>]- Name-
If you specify this parameter, only permissions that match the specified name are displayed.
[-object-name <text>]- Object Name-
If you specify this parameter, only permissions that match the specified object-name are displayed.
[-permission <text>]- Permission-
If you specify this parameter, only permissions that match the specified permission are displayed.
[-command-name <text>]- Command Name-
If you specify this parameter, only permissions that match the specified command-name are displayed.
The following example shows all the the allowed and disallowed system objects
cluster1::> template show-permissions
Template: VserverEnvironmentSetup
Object Name Command Name Permission
access.dns vserver services name-service dns create allowed
network.interface network interface create allowed
network.routes network route create allowed
protocols.CIFS vserver cifs create allowed
