ONTAP commands
template show-permissions
Display Template Allowed and Disallowed System Objects
The template show-permission command shows all the system objects that are allowed and disallowed for the current user.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-name <text>] - Name
If you specify this parameter, only permissions that match the specified name are displayed.
[-object-name <text>] - Object Name
If you specify this parameter, only permissions that match the specified object-name are displayed.
[-permission <text>] - Permission
If you specify this parameter, only permissions that match the specified permission are displayed.
[-command-name <text>] - Command Name
If you specify this parameter, only permissions that match the specified command-name are displayed.
The following example shows all the the allowed and disallowed system objects
cluster1::> template show-permissions
    Template: VserverEnvironmentSetup
    Object Name          Command Name                                Permission
    access.dns           vserver services name-service dns create    allowed
    network.interface    network interface create                    allowed
    network.routes       network route create                        allowed
    protocols.CIFS       vserver cifs create                         allowed
