template show-permissions
Display Template Allowed and Disallowed System Objects
The template show-permission command shows all the system objects that are allowed and disallowed for the current user.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-name <text>]
- Name-
If you specify this parameter, only permissions that match the specified name are displayed.
[-object-name <text>]
- Object Name-
If you specify this parameter, only permissions that match the specified object-name are displayed.
[-permission <text>]
- Permission-
If you specify this parameter, only permissions that match the specified permission are displayed.
[-command-name <text>]
- Command Name-
If you specify this parameter, only permissions that match the specified command-name are displayed.
The following example shows all the the allowed and disallowed system objects
cluster1::> template show-permissions Template: VserverEnvironmentSetup Object Name Command Name Permission -------------------- ------------------------------------------- ------------ access.dns vserver services name-service dns create allowed network.interface network interface create allowed network.routes network route create allowed protocols.CIFS vserver cifs create allowed
