vserver nfs on
PDF of this doc site
Creating your file...
Your file is ready
Enable the NFS service of a Vserver
The vserver nfs on
command enables NFS access on a Vserver. The Vserver must already exist.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which you want to enable NFS access.
The following example enables NFS access on a Vserver named vs0.
cluster1::> vserver nfs on -vserver vs0
