The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
lun portset delete
PDF of this doc site
Creating your file...
Your file is ready
Delete the portset
This command deletes an existing portset. By default, you cannot delete a portset if it is bound to an initiator group. If a portset is bound to an initiator group, you can do one of the following:
specify the
force
option to unbind the portset from the initiator group and delete the portset. -
use the lun igroup unbind command to unbind the portset from the initiator group. Then you can delete the portset.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-portset <text>
- Portset Name-
Specifies the portset you want to delete.
[-f, -force <true>]
- Force-
Forcibly unbinds the portset from the initiator group.
cluster1::> portset delete -vserver vs1 -portset ps1
Deletes portset ps1 on Vserver vs1.
