ONTAP commands
lun portset delete
Delete the portset
This command deletes an existing portset. By default, you cannot delete a portset if it is bound to an initiator group. If a portset is bound to an initiator group, you can do one of the following:
  • specify the force option to unbind the portset from the initiator group and delete the portset.
  • use the lun igroup unbind command to unbind the portset from the initiator group. Then you can delete the portset.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-portset <text> - Portset Name
Specifies the portset you want to delete.
[-f, -force <true>] - Force
Forcibly unbinds the portset from the initiator group.
cluster1::> portset delete -vserver vs1 -portset ps1
Deletes portset ps1 on Vserver vs1.
