      lun portset delete
Delete the portset
This command deletes an existing portset. By default, you cannot delete a portset if it is bound to an initiator group. If a portset is bound to an initiator group, you can do one of the following:
specify the forceoption to unbind the portset from the initiator group and delete the portset.
use the lun igroup unbind command to unbind the portset from the initiator group. Then you can delete the portset.
- -vserver <Vserver Name>- Vserver Name
Specifies the Vserver.
- -portset <text>- Portset Name
Specifies the portset you want to delete.
- [-f, -force <true>]- Force
Forcibly unbinds the portset from the initiator group.
cluster1::> portset delete -vserver vs1 -portset ps1
Deletes portset ps1 on Vserver vs1.
 PDFs
PDFs
