security login whoami
PDF of this doc site
Creating your file...
Your file is ready
Show the current user and role of this session
The security login whoami
command displays the name and role of the user logged in at the current console session. It takes no options or other parameters.
The following example shows that the current session is logged in by using the 'admin' user account:
cluster1::> whoami (security login whoami) User: admin Role: admin
