Command reference
security login whoami
Show the current user, trust score of the user and role of this session
The security login whoami command displays the name, role and the trust score of the user logged in at the current console session. It takes no options or other parameters.
The following example shows that the current session is logged in by using the 'admin' user account:
cluster1::> whoami
              (security login whoami)
User: admin
            Role: admin
     Trust Score: 90
