The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver export-policy rename
PDF of this doc site
Creating your file...
Your file is ready
Rename an export policy
The vserver export-policy rename
command renames an export policy.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the export policy is located.
-policyname <export policy name>
- Policy Name-
This parameter specifies the export policy that you want to rename.
-newpolicyname <export policy name>
- New Export Policy Name-
This parameter specifies the new name of the export policy.
The following example renames an export policy named user_expolicy with the name read_only_expolicy on a Vserver named vs0:
vs1::> vserver export-policy rename -vserver vs0 -policyname user_expolicy -newpolicyname read_only_expolicy
