      vserver export-policy rename
Rename an export policy
The vserver export-policy rename command renames an export policy.
- -vserver <vserver name>- Vserver
This parameter specifies the Vserver on which the export policy is located.
- -policyname <export policy name>- Policy Name
This parameter specifies the export policy that you want to rename.
- -newpolicyname <export policy name>- New Export Policy Name
This parameter specifies the new name of the export policy.
The following example renames an export policy named user_expolicy with the name read_only_expolicy on a Vserver named vs0:
vs1::> vserver export-policy rename -vserver vs0 -policyname user_expolicy -newpolicyname read_only_expolicy
 PDFs
PDFs
