The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume snaplock prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Prepares the system for downgrade
The volume snaplock prepare-to-downgrade
command prepares nodes to downgrade to a release without SnapLock volume append mode feature. Prior to disabling the feature, the command disables volume append mode on all SnapLock volumes in the cluster.
The following example disables the SnapLock volume append mode feature in the local cluster:
cluster1::> volume snaplock prepare-to-downgrade
