volume snaplock prepare-to-downgrade
Prepares the system for downgrade
The volume snaplock prepare-to-downgrade command prepares nodes to downgrade to a release without SnapLock volume append mode feature. Prior to disabling the feature, the command disables volume append mode on all SnapLock volumes in the cluster.
The following example disables the SnapLock volume append mode feature in the local cluster:
cluster1::> volume snaplock prepare-to-downgrade
