volume clone split stop
PDF of this doc site
Creating your file...
Stop an ongoing FlexClone split job
The volume clone split stop
command stops the process of separating the FlexClone volume from its underlying parent volume, but does not lose any of the progress achieved while the split process was active. That is, all the clone volume blocks already separated from the parent volume remain separated. If you restart the split operation, splitting process begins from the beginning because no information about previously achieved progress is saved, but previously split blocks are not re-split. This command is only supported for flexible volumes.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver that the FlexClone volume exists on.
-flexclone <volume name>
- FlexClone Volume-
This specifies the FlexClone volume whose separation from the parent volume will be stopped.
The following example stops an ongoing clone splitting job for FlexClone volume fc_vol_1
on Vserver vs1
cluster1::> volume clone split stop -vserver vs1 -flexclone fc_vol_1
