The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system bridge coredump collect
PDF of this doc site
Creating your file...
Your file is ready
Retrieve and save coredump
The system bridge coredump collect
command retrieves a core file from a bridge.
-name <text>
- Bridge Name-
This parameter specifies the bridge name from which the coredump file is to be collected.
The following example retrieves a coredump from bridge ATTO_FibreBridge7500N_1:
cluster1::> system bridge coredump collect -bridge ATTO_FibreBridge7500N_1 [Job 883] Job is queued: Collect the coredump from bridge "ATTO_FibreBridge7500N_1". cluster1::>
