system bridge coredump collect
Retrieve and save coredump
The system bridge coredump collect command retrieves a core file from a bridge.
-name <text> - Bridge Name
This parameter specifies the bridge name from which the coredump file is to be collected.
The following example retrieves a coredump from bridge ATTO_FibreBridge7500N_1:
cluster1::> system bridge coredump collect -bridge ATTO_FibreBridge7500N_1
[Job 883] Job is queued: Collect the coredump from bridge "ATTO_FibreBridge7500N_1".
cluster1::>
