security login rest-role expanded-rest-roles modify
PDF of this doc site
Creating your file...
Your file is ready
Modify the status of Expanded REST roles for granular resource control feature
The security login rest-role expanded-rest-roles modify
command enables or disables Expanded REST roles for granular resource control
feature.
[-is-enabled {true|false}]
- Is Enabled? (privilege: advanced)-
This parameter specifies whether the
feature is enabled or disabled. The default value istrue
i.e. the feature is enabled by default.
The following command disables the Expanded REST roles for granular resource control
feature.
cluster1::*> security login rest-role expanded-rest-roles modify -is-enabled false cluster1::*>
