security login rest-role expanded-rest-roles modify
Modify the status of Expanded REST roles for granular resource control feature
The security login rest-role expanded-rest-roles modify command enables or disables Expanded REST roles for granular resource control feature.
[-is-enabled {true|false}] - Is Enabled?
This parameter specifies whether the Expanded REST roles for granular resource control feature is enabled or disabled. The default value is true i.e. the feature is enabled by default.
The following command disables the Expanded REST roles for granular resource control feature.
cluster1::*> security login rest-role expanded-rest-roles modify -is-enabled false
cluster1::*>
