network bgp config create
PDF of this doc site
Creating your file...
Create BGP configuration
The network bgp config create
command is used to create the border gateway protocol (BGP) configuration for a node. It can be used to override the BGP parameters defined in the global BGP defaults.
-node {<nodename>|local}
- Node-
This parameter specifies the node on which configuration details will be created.
-asn <integer>
- Autonomous System Number-
This parameter specifies the autonomous system number (ASN). The ASN attribute is a positive integer of the range from 1 to 4,294,967,295. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use" or the AS number assigned to the operator's organization.
-hold-time <integer>
- Hold Time-
This parameter specifies the hold time in seconds. The default value is 180.
-router-id <IP Address>
- Router ID-
This parameter specifies the local router ID. The router-id value takes the form of an IPv4 address. The default router-id will be initialized using a local IPv4 address in admin vserver.
cluster1::> network bgp config create -node node1 -asn 10 -hold-time 180 -router-id 10.0.1.112
