network bgp config create
Create BGP configuration
The network bgp config create command is used to create the border gateway protocol (BGP) configuration for a node. It can be used to override the BGP parameters defined in the global BGP defaults.
- -node {<nodename>|local}- Node
This parameter specifies the node on which configuration details will be created.
- -asn <integer>- Autonomous System Number
This parameter specifies the autonomous system number (ASN). The ASN attribute is a positive integer of the range from 1 to 4,294,967,295. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use" or the AS number assigned to the operator's organization.
- -hold-time <integer>- Hold Time
This parameter specifies the hold time in seconds. The default value is 180.
- -router-id <IP Address>- Router ID
This parameter specifies the local router ID. The router-id value takes the form of an IPv4 address. The default router-id will be initialized using a local IPv4 address in admin vserver.
cluster1::> network bgp config create -node node1 -asn 10 -hold-time 180 -router-id 10.0.1.112
 PDFs
PDFs
