system switch ethernet threshold show
Display the Ethernet switch health monitor alert thresholds
The system switch ethernet threshold show
command displays thresholds used by health monitor alerts.
cluster1::> system switch ethernet threshold show Errors/Utilization Threshold is per 0.10% values: 1 = 0.10%, 5 = 0.50% Entity-alert Threshold is the count needed to raise entity warning alert Errors Bandwidth Threshold (0.1%) Threshold (0.1%) Entity-alert In Out In Out Threshold -------- -------- -------- -------- ------------ 1 1 900 900 2
Displays the inbound and outbound switch interface packet error thresholds which are set at 0.1%, and the inbound and outbound switch interface bandwidth utilization thresholds which are set at 90%. Also displays the threshold value for entity warning alerts. The node platform health monitor also shares the same thresholds for monitoring cluster port packet errors on the node.
