security config ocsp enable
PDF of this doc site
Creating your file...
Enable OCSP for one or more selected applications
The security config ocsp enable
command enables the OCSP-based certificate status check for applications supporting SSL/TLS communications. For more information about the OCSP-based certificate status check for applications supporting SSL/TLS communications, see the security config ocsp show command.
-application <SSL/TLS Application supporting OCSP>,…
- List of Applications (privilege: advanced)-
Use this parameter to specify the application to enable the OCSP support. To enable all applications, the value 'all' can be used. Note: You cannot specify the value 'all' with other applications.
The following example enables the OCSP support for AutoSupport and EMS applications:
cluster1::*> security config ocsp enable -application autosupport,ems cluster1::> security config ocsp show Application OCSP Enabled? -------------------- ------------- autosupport true audit_log false fabricpool false ems true kmip false ldap false ssh true 6 entries were displayed.
The following example enables the OCSP support for all applications:
cluster1::*> security config ocsp enable -application all Warning: OCSP will be enabled for all applications. Any previous modifications will be ignored. Do you want to continue? {y|n}: y cluster1::*> security config ocsp show Application OCSP Enabled? -------------------- ------------- autosupport true audit_log true fabricpool true ems true kmip true ldap true ssh true 6 entries were displayed.
