lun transition 7-mode show
Display the 7-Mode LUN Inventory
The lun transition 7-mode show command displays information about LUNs copied from a Data ONTAP 7-Mode system. If no parameters are specified, the command displays the following information about all 7-Mode LUNs:
Vserver name
LUN path
Operating system type
Size
Whether or not the LUN has been transitioned to clustered Data ONTAP
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
Selects the 7-Mode LUNs in the specified Vserver.
 [-path <path>]- LUN Path (privilege: advanced)-
Selects the 7-Mode LUNs with the specified path.
 [-volume <volume name>]- Volume Name (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified volume.
 [-ostype <LUN Operating System Format>]- OS Type (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified operating system type.
 [-size <size>]- LUN Size (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified size.
 [-prefix-size <size>]- Prefix Stream Size (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified prefix stream size.
 [-suffix-size <size>]- Suffix Stream Size (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified suffix stream size.
 [-serial <text>]- Serial Number (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified serial number for clustered Data ONTAP. LUNs where
is-transitionedisfalsedo not have a serial number assigned for clustered Data ONTAP. [-uuid <UUID>]- UUID (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified UUID for clustered Data ONTAP. LUNs where
is-transitionedisfalsedo not have a UUID assigned for clustered Data ONTAP. [-serial-7-mode <text>]- 7-mode Serial Number (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified serial number from 7-Mode.
 [-is-transitioned {true|false}]- Transition Complete (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified transition state. LUNs where this value is
truehave been transitioned and are available to be mapped for client access. LUNs where this value isfalsehave not yet been transitioned and may not be mapped. [-vserver-uuid <UUID>]- Vserver UUID (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified Vserver UUID.
 [-node <nodename>]- Node (privilege: advanced)-
Selects the 7-Mode LUNs that match the specified node name.
The following example displays a summary of all 7-Mode LUNs for the volume vol1 in a Vserver named vs1 :
cluster1::*> lun transition 7-mode show -vserver vs1 -volume vol1
Vserver   Path                         Type     Size   Transitioned
vs1       /vol/vol1/lun1               linux      10MB false
          /vol/vol1/lun2               linux     500MB true
          /vol/vol1/lun3               linux     500MB true
8 entries were displayed.
The following example displays detailed information for the 7-Mode LUN /vol/vol1/lun2 in a Vserver named vs1 :
cluster1::*> lun transition 7-mode show -vserver vs1 -path /vol/vol1/lun2
Vserver Name: vs1
            LUN Path: /vol/vol1/lun2
         Volume Name: vol1
             OS Type: linux
            LUN Size: 500MB
  Prefix Stream Size: 0
  Suffix Stream Size: 0
       Serial Number: BCVvv$DLZu8g
                UUID: f53d603b-9663-4567-9680-95c1a9cc6d9e
7-mode Serial Number: C4eqKotPI8Ui
 Transition Complete: true
        Vserver UUID: be4cc135-163f-11e3-931f-123478563412
                Node: cluster-01
