system smtape status show
PDF of this doc site
Creating your file...
Show status of SMTape sessions
This command lists the status of all SMTape sessions in the cluster. By default, this command lists the following information:
Session
Type
Status
Progress
Path
Device
Node
[-fields <fieldname>,…]
Use this parameter to display additional fields about each session apart from the default entries. This parameter is optional. Any combination of the following fields is valid:
Session
Node
Type
Status
Path
Device
Progress
Start-time
End-time
Update-time
Backup-snapshot
Tape-block-size
[-instance ]
Displays detailed information about the specified sessions.
[-session <Sequence Number>]
- Session Identifier-
Selects information about a specific SMTape session. A Session Identifier is a number that is used to identify a particular SMTape session.
[-node {<nodename>|local}]
- Node Name-
Selects information about sessions related to the specified node.
[-type {backup|restore}]
- Operation Type-
Selectsinformation about SMTape sessions of the specified operation type.
[-status {COMPLETED|FAILED|ACTIVE|WAITING|ABORTING|UNKNOWN}]
- Session Status-
Selects information about SMTape sessions having the specified status in the parameter.
[-path <text>]
- Path Name-
Selects information about SMTape sessions on a volume which is at the specified path name. This is the logical path of the volume and you must specify the path name in the following format: /
vserver_name
/volume_name
. [-device <text>]
- Device Name-
Selects information about the SMTape sessions on the specified tape device. You must specify the tape device name in the following format: /
node_name
/tape_device
. [-progress {<integer>[KB|MB|GB|TB|PB]}]
- Bytes Transferred-
Selects information about SMTape sessions in which the number of data bytes transferred in a particular session matches with the number specified in this parameter.
[-start-time <MM/DD/YYYY HH:MM:SS>]
- Start Time-
Selects information about SMTape sessions whose starting time matches the specified starting time.
[-end-time <MM/DD/YYYY HH:MM:SS>]
- End Time-
Selects information about SMTape sessions whose ending time matches the specified ending time.
[-backup-snapshot <snapshot name>]
- Snapshot Name-
Selects information about SMTape sessions that use a particular Snapshot copy name which matches the specified Snapshot copy name in the parameter in backup or restore operations.
[-tape-block-size <integer>]
- Tape Block Size-
Selects information about SMTape sessions that use a particular tape block size which matches the specified tape block size parameter in backup or restore operations.
[-error <text>]
- Error Description-
Selects information about SMTape sessions that have a particular error description which matches the specified error description in the parameter.
Displays default entries about the five SMTape sessions.
cluster1::> system smtape status show Session Type Status Progress Path Device Node ------- ------- --------- -------- ------------ --------------- ----------- 5 Backup COMPLETED 50MB /vsrvr1/vol1 /cls1-01/nrst0l cluster1-01 4 Restore FAILED 0B /vsrvr1/vol3 /cls1-02/nrst2l cluster1-02 3 Backup COMPLETED 50MB /vsrvr1/vol3 /cls1-01/nrst0l cluster1-01 2 Backup COMPLETED 50MB /vsrvr1/vol2 /cls1-03/nrst0m cluster1-03 1 Backup COMPLETED 50KB /vsrvr1/vol5 /cls1-01/nrst0n cluster1-01 5 entries were displayed.
The following example shows the output with the -instance
argument.
cluster1::> system smtape status show -instance Session Identifier: 1 Node Name: node1 Operation Type: Backup Status: COMPLETED Path Name: /vs1/vol1 Device Name: /node1/rst0a Bytes Transferred: 2048 Start Time: 1/4/2012 14:26:24 End Time: 1/4/2012 14:29:45 Last updated: 1/4/2012 14:29:45 Snapshot Name: vol1.snapshot Tape Block Size: 240 Error Description: None
