system smtape status show
Show status of SMTape sessions
This command lists the status of all SMTape sessions in the cluster. By default, this command lists the following information:
  • Session
  • Type
  • Status
  • Progress
  • Path
  • Device
  • Node
{ [-fields <fieldname>,…​]
Use this parameter to display additional fields about each session apart from the default entries. This parameter is optional. Any combination of the following fields is valid:
  • Session
  • Node
  • Type
  • Status
  • Path
  • Device
  • Progress
  • Start-time
  • End-time
  • Update-time
  • Backup-snapshot
  • Tape-block-size
  • Error
| [-instance ] }
Displays detailed information about the specified sessions.
[-session <Sequence Number>] - Session Identifier
Selects information about a specific SMTape session. A Session Identifier is a number that is used to identify a particular SMTape session.
[-node {<nodename>|local}] - Node Name
Selects information about sessions related to the specified node.
[-type {backup|restore}] - Operation Type
Selectsinformation about SMTape sessions of the specified operation type.
[-status {COMPLETED|FAILED|ACTIVE|WAITING|ABORTING|UNKNOWN}] - Session Status
Selects information about SMTape sessions having the specified status in the parameter.
[-path <text>] - Path Name
Selects information about SMTape sessions on a volume which is at the specified path name. This is the logical path of the volume and you must specify the path name in the following format: /vserver_name /volume_name .
[-device <text>] - Device Name
Selects information about the SMTape sessions on the specified tape device. You must specify the tape device name in the following format: /node_name /tape_device .
[-progress {<integer>[KB|MB|GB|TB|PB]}] - Bytes Transferred
Selects information about SMTape sessions in which the number of data bytes transferred in a particular session matches with the number specified in this parameter.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
Selects information about SMTape sessions whose starting time matches the specified starting time.
[-end-time <MM/DD/YYYY HH:MM:SS>] - End Time
Selects information about SMTape sessions whose ending time matches the specified ending time.
[-backup-snapshot <snapshot name>] - Snapshot Name
Selects information about SMTape sessions that use a particular Snapshot copy name which matches the specified Snapshot copy name in the parameter in backup or restore operations.
[-tape-block-size <integer>] - Tape Block Size
Selects information about SMTape sessions that use a particular tape block size which matches the specified tape block size parameter in backup or restore operations.
[-error <text>] - Error Description
Selects information about SMTape sessions that have a particular error description which matches the specified error description in the parameter.
Displays default entries about the five SMTape sessions.
cluster1::> system smtape status show
Session Type    Status    Progress  Path         Device          Node
5       Backup  COMPLETED     50MB  /vsrvr1/vol1 /cls1-01/nrst0l cluster1-01
4       Restore FAILED          0B  /vsrvr1/vol3 /cls1-02/nrst2l cluster1-02
3       Backup  COMPLETED     50MB  /vsrvr1/vol3 /cls1-01/nrst0l cluster1-01
2       Backup  COMPLETED     50MB  /vsrvr1/vol2 /cls1-03/nrst0m cluster1-03
1       Backup  COMPLETED     50KB  /vsrvr1/vol5 /cls1-01/nrst0n cluster1-01
5 entries were displayed.
The following example shows the output with the -instance argument.
cluster1::> system smtape status show -instance
Session Identifier: 1
         Node Name: node1
    Operation Type: Backup
            Status: COMPLETED
         Path Name: /vs1/vol1
       Device Name: /node1/rst0a
 Bytes Transferred: 2048
        Start Time: 1/4/2012 14:26:24
          End Time: 1/4/2012 14:29:45
      Last updated: 1/4/2012 14:29:45
     Snapshot Name: vol1.snapshot
   Tape Block Size: 240
 Error Description: None
