system smtape status show
Show status of SMTape sessions
This command lists the status of all SMTape sessions in the cluster. By default, this command lists the following information:
Session
Type
Status
Progress
Path
Device
Node
[-fields <fieldname>,…]
Use this parameter to display additional fields about each session apart from the default entries. This parameter is optional. Any combination of the following fields is valid:
Session
Node
Type
Status
Path
Device
Progress
Start-time
End-time
Update-time
Backup-snapshot
Tape-block-size
[-instance ]
Displays detailed information about the specified sessions.
[-session <Sequence Number>]
- Session Identifier-
Selects information about a specific SMTape session. A Session Identifier is a number that is used to identify a particular SMTape session.
[-node {<nodename>|local}]
- Node Name-
Selects information about sessions related to the specified node.
[-type {backup|restore}]
- Operation Type-
Selectsinformation about SMTape sessions of the specified operation type.
[-status {COMPLETED|FAILED|ACTIVE|WAITING|ABORTING|UNKNOWN}]
- Session Status-
Selects information about SMTape sessions having the specified status in the parameter.
[-path <text>]
- Path Name-
Selects information about SMTape sessions on a volume which is at the specified path name. This is the logical path of the volume and you must specify the path name in the following format: /
vserver_name
/volume_name
. [-device <text>]
- Device Name-
Selects information about the SMTape sessions on the specified tape device. You must specify the tape device name in the following format: /
node_name
/tape_device
. [-progress {<integer>[KB|MB|GB|TB|PB]}]
- Bytes Transferred-
Selects information about SMTape sessions in which the number of data bytes transferred in a particular session matches with the number specified in this parameter.
[-start-time <MM/DD/YYYY HH:MM:SS>]
- Start Time-
Selects information about SMTape sessions whose starting time matches the specified starting time.
[-end-time <MM/DD/YYYY HH:MM:SS>]
- End Time-
Selects information about SMTape sessions whose ending time matches the specified ending time.
[-backup-snapshot <snapshot name>]
- Snapshot Name-
Selects information about SMTape sessions that use a particular Snapshot copy name which matches the specified Snapshot copy name in the parameter in backup or restore operations.
[-tape-block-size <integer>]
- Tape Block Size-
Selects information about SMTape sessions that use a particular tape block size which matches the specified tape block size parameter in backup or restore operations.
[-error <text>]
- Error Description-
Selects information about SMTape sessions that have a particular error description which matches the specified error description in the parameter.
Displays default entries about the five SMTape sessions.
cluster1::> system smtape status show Session Type Status Progress Path Device Node ------- ------- --------- -------- ------------ --------------- ----------- 5 Backup COMPLETED 50MB /vsrvr1/vol1 /cls1-01/nrst0l cluster1-01 4 Restore FAILED 0B /vsrvr1/vol3 /cls1-02/nrst2l cluster1-02 3 Backup COMPLETED 50MB /vsrvr1/vol3 /cls1-01/nrst0l cluster1-01 2 Backup COMPLETED 50MB /vsrvr1/vol2 /cls1-03/nrst0m cluster1-03 1 Backup COMPLETED 50KB /vsrvr1/vol5 /cls1-01/nrst0n cluster1-01 5 entries were displayed.
The following example shows the output with the -instance
argument.
cluster1::> system smtape status show -instance Session Identifier: 1 Node Name: node1 Operation Type: Backup Status: COMPLETED Path Name: /vs1/vol1 Device Name: /node1/rst0a Bytes Transferred: 2048 Start Time: 1/4/2012 14:26:24 End Time: 1/4/2012 14:29:45 Last updated: 1/4/2012 14:29:45 Snapshot Name: vol1.snapshot Tape Block Size: 240 Error Description: None
