security key-manager external aws check
Show detailed status of the AWS KMS configurations
This command displays the Amazon Web Service (AWS) Key Management Service (KMS) status.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
If this parameter is specified then the command displays only the AWS KMS status for the given node.
- [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)
If this parameter is specified then the command displays only the AWS KMS status for the given Vserver.
- [-category <Categories for Cloud KMS status check>]- Component (privilege: advanced)
If this parameter is specified then the command displays only the AWS KMS status for the given category.
            Category                    Description
            service_reachability        Cloud KMS Reachability
            ekmip_server                Embedded KMIP Server Reachability
            kms_wrapped_key_status      Status of KMS Wrapped Keys On Cluster
- [-status <Status Check>]- Status (privilege: advanced)
If this parameter is specified then the command displays only the AWS KMS status entries matching the given status.
            OK
            FAILED
            UNKNOWN
- [-detail <text>]- Status Details (privilege: advanced)
This field displays a detailed status message, if available.
The example below displays the status of all components of all AWS KMS instances configured on node vsim1.
cluster-1::> security key-manager external aws check -node vsim1
Vserver: vs1
Node: vsim1
Category: service_reachability
              Status: OK
Category: ekmip_server
              Status: OK
Category: kms_wrapped_key_status
              Status: OK
 PDFs
PDFs
