security key-manager external aws check
Show detailed status of the AWS KMS configurations
This command displays the Amazon Web Service (AWS) Key Management Service (KMS) status.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
If this parameter is specified then the command displays only the AWS KMS status for the given node.
[-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
If this parameter is specified then the command displays only the AWS KMS status for the given Vserver.
[-category <Categories for Cloud KMS status check>]- Component (privilege: advanced)-
If this parameter is specified then the command displays only the AWS KMS status for the given category.
Category Description -------- ----------- service_reachability Cloud KMS Reachability ekmip_server Embedded KMIP Server Reachability kms_wrapped_key_status Status of KMS Wrapped Keys On Cluster [-status <Status Check>]- Status (privilege: advanced)-
If this parameter is specified then the command displays only the AWS KMS status entries matching the given status.
OK FAILED UNKNOWN [-detail <text>]- Status Details (privilege: advanced)-
This field displays a detailed status message, if available.
The example below displays the status of all components of all AWS KMS instances configured on node vsim1.
cluster-1::> security key-manager external aws check -node vsim1
Vserver: vs1
Node: vsim1
Category: service_reachability
Status: OK
Category: ekmip_server
Status: OK
Category: kms_wrapped_key_status
Status: OK
