storage aggregate reallocation quiesce
PDF of this doc site
Creating your file...
Your file is ready
Quiesce reallocate job on aggregate
Temporarily stops any reallocation jobs that are in progress. When you use this command, the persistent state is saved. You can use the storage aggregate reallocation restart command to restart a job that is quiesced.
There is no limit to how long a job can remain in the quiesced (paused) state.
-aggregate <aggregate name>
- Aggregate Name-
Specifies the aggregate on which you want to temporarily pause the job.
cluster1::> storage aggregate reallocation quiesce -aggregate aggr0
Temporarily stops (pauses) any reallocation job running on aggregate aggr0.
