The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
template rename
PDF of this doc site
Creating your file...
Your file is ready
Rename a template
Use this command to rename an existing template.
-name <template name>
- Name of the template-
This parameter specifies the name of the template.
-new-name <template name>
- New name of the template-
This parameter specifies the template's new name.
The following example renames a template template1 as template2:
cluster1::> template rename -name template1 -new-name template2
