The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network options port-health-monitor show
PDF of this doc site
Creating your file...
Your file is ready
Display port health monitors configuration
This command displays the enabled port health monitors for the IPspaces in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-ipspace <IPspace>]
- IPspace Name (privilege: advanced)-
Displays the port health monitors that are enabled only for the given IPspace name.
[-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}]
- List of Enabled Port Health Monitors (privilege: advanced)-
Displays the IPspaces that have the given monitors enabled.
The following example lists all port health monitors that are enabled for all IPspaces in the cluster.
cluster1::*> network options port-health-monitor show IPspace Enabled Port Health Monitors ------------- ---------------------------- Cluster l2_reachability, link_flapping Default l2_reachability, link_flapping 2 entries were displayed.
