network options port-health-monitor show
Display port health monitors configuration
This command displays the enabled port health monitors for the IPspaces in the cluster.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-ipspace <IPspace>]- IPspace Name (privilege: advanced)-
Displays the port health monitors that are enabled only for the given IPspace name.
[-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}]- List of Enabled Port Health Monitors (privilege: advanced)-
Displays the IPspaces that have the given monitors enabled.
The following example lists all port health monitors that are enabled for all IPspaces in the cluster.
cluster1::*> network options port-health-monitor show
IPspace Enabled Port Health Monitors
Cluster l2_reachability,
link_flapping
Default l2_reachability,
link_flapping
2 entries were displayed.
