network options port-health-monitor show
Display port health monitors configuration
This command displays the enabled port health monitors for the IPspaces in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-ipspace <IPspace>] - IPspace Name
Displays the port health monitors that are enabled only for the given IPspace name.
[-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}] - List of Enabled Port Health Monitors
Displays the IPspaces that have the given monitors enabled.
The following example lists all port health monitors that are enabled for all IPspaces in the cluster.
cluster1::*> network options port-health-monitor show
IPspace         Enabled Port Health Monitors
Cluster         l2_reachability,
                link_flapping
Default         l2_reachability,
                link_flapping
2 entries were displayed.
