      network options port-health-monitor show
Display port health monitors configuration
This command displays the enabled port health monitors for the IPspaces in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-ipspace <IPspace>]- IPspace Name (privilege: advanced)
Displays the port health monitors that are enabled only for the given IPspace name.
- [-health-monitors {l2-reachability|link-flapping|crc-errors|vswitch-link}]- List of Enabled Port Health Monitors (privilege: advanced)
Displays the IPspaces that have the given monitors enabled.
The following example lists all port health monitors that are enabled for all IPspaces in the cluster.
cluster1::*> network options port-health-monitor show
IPspace         Enabled Port Health Monitors
Cluster         l2_reachability,
                link_flapping
Default         l2_reachability,
                link_flapping
2 entries were displayed.
 PDFs
PDFs
