The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port vip create
PDF of this doc site
Creating your file...
Your file is ready
Create a VIP port
The network port vip create
command creates a VIP port in the specified IPspace on the specified node. Only one VIP port can be created per IPspace on the given node.
-node {<nodename>|local}
- Node-
The node where the VIP port should be created.
-port <netport>
- Network Port-
The name of the VIP port to be created in the format v<slot-number><port-letter>
-ipspace <IPspace>
- IPspace Name-
The IPspace where the VIP port should be created. The default value for this parameter is "Default", which identifies the default IPspace.
This example shows how to create a VIP port named v0a in ipspace ips on node1.
cluster1::> network port vip create -node node1 -port v0a -ipspace ips
