      network port vip create
Create a VIP port
The network port vip create command creates a VIP port in the specified IPspace on the specified node. Only one VIP port can be created per IPspace on the given node.
- -node {<nodename>|local}- Node
The node where the VIP port should be created.
- -port <netport>- Network Port
The name of the VIP port to be created in the format v<slot-number><port-letter>
- -ipspace <IPspace>- IPspace Name
The IPspace where the VIP port should be created. The default value for this parameter is "Default", which identifies the default IPspace.
This example shows how to create a VIP port named v0a in ipspace ips on node1.
cluster1::> network port vip create -node node1 -port v0a -ipspace ips
 PDFs
PDFs
