vserver services ndmp extensions modify
- PDF of this doc site
Creating your file...
Your file is ready
Modify NDMP extension status
This command is used to enable/disable an NDMP extension in the Vserver-aware NDMP mode.
[-is-extension-0x2050-enabled {true|false}]
- Is Extension 0x2050 Enabled (privilege: advanced)-
If this parameter is specified, the command can be used to modify the status of the extension in the Vserver-aware mode.
The following example shows how to enable NDMP extenion 0x2050 in the Vserver-aware NDMP mode of operation:
cluster1::> vserver services ndmp extension modify -is-extension-0x2050-enabled true cluster1::>
