network bgp config modify
Modify BGP configuration
The network bgp config modify command is used to modify a node's border gateway protocol (BGP) configuration.
- -node {<nodename>|local}- Node
This parameter specifies the node on which BGP configuration will be modified.
- [-asn <integer>]- Autonomous System Number
This parameter specifies the autonomous system number (ASN). The ASN attribute is a positive integer of the range from 1 to 4,294,967,295. It should typically be chosen from RFC6996 "Autonomous System (AS) Reservation for Private Use" or the AS number assigned to the operator's organization.
- [-hold-time <integer>]- Hold Time
This parameter specifies the hold time in seconds.
- [-router-id <IP Address>]- Router ID
This parameter specifies the local router ID. The router-id value takes the form of an IPv4 address.
cluster1::> network bgp config modify -node node1 -router-id 1.1.1.1 -asn 20
 PDFs
PDFs
