system node root-mount show
Show the existing mounts from any node to another node's root volume.
The system node root-mount show command displays the status of current root-mounts from any node to another node's root volume. These root-mounts are used by cluster services to access data on other nodes in the cluster. These root-mounts are not pre-created, but are created as they are needed. They can also be manually created or deleted.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Owner of the Root-mount-
Selects information about root-mounts that exist on the specified node.
[-root-node <nodename>]- Root-mount Destination Node-
Selects information about root-mounts that connect to the specified node.
[-create-time <MM/DD/YYYY HH:MM:SS>]- Mount Creation Time-
Selects information about root-mounts that were created at the specified time.
[-state <Mount State>]- State of the Root-Mount-
Selects information about root-mounts that have the specified state. The states are:
unknown: The state of the root-mount is being determined. -
initializing: A root-mount was found and needs testing to determine the correct state. -
mount-requested: The root-mount has been requested, but is not ready. -
mounting: The root-mount is being created, but is not ready. -
ready: The root-mount is ready to be used. -
not-responding: The root-mount exists but is not responding. -
does-not-exist: No root-mount is possible to this node's root volume. -
ha-busy: The root-mount is busy pending completion of an HA event. -
clean-up-requested: The root-mount is being deleted. -
cleaning-up: The root-mount is being deleted. -
create-error: The root-mount could not be created.
[-last-error <text>]- Last Error-
Selects information about root-mounts that have the specified last-error value.
+ The following example shows the default state of the root-mounts on a cluster that is not using root-node services:
cluster1::> system node root-mount show This table is currently empty.
+ The following example displays the root-mounts that exist for a cluster that has ``_nodeA_`` mounted to ``_nodeB_`` , and ``_nodeB_`` mounted to ``_nodeA_`` :
cluster1::> system node root-mount show Node Root Node State Last Error ----------------- ----------------- ----------- ------------------------------- nodeA nodeB ready nodeB nodeA ready 2 entries were displayed.
